简介
This guide will serve to assist in replacing the plastic earbud housing in the case itself. In order to complete these steps, you will need a 3.5mm flathead screw bit and an ESD-safe prying tool. One reason you may need to do this is to replace the magnets that hold the case itself shut.
你所需要的
Use an ESD-safe pry tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
另外一个人完成了本指南。
