简介
Follow this guide if you need to replace the platter of your Heyday Suitcase Turntable. The platter is where you place the record or vinyl and holds it in place. If the platter is damaged or not placed correctly, it will affect the sound quality.
Before beginning this guide, turn off the record player and disconnect the power cord.
你所需要的
在这个步骤中使用的工具:Tweezers$3.99
Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
Once you have removed the platter, you can replace the platter. Once you have replaced the platter, press the spindle shaft back into place.
