跳转到主内容
Heyday Round Bluetooth Speaker Motherboard Replacement
你所需要的
  1. Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker: 步骤 1 中的图像 1,2 Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker: 步骤 1 中的图像 2,2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
  3. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  4. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once the hardware is opened by the screwdriver, both sides of the motherboard will be exposed and ready for any needed repairs.
  5. Heyday Round Bluetooth Speaker Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
  6. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 6 中的图像 1,2 Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
  7. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the motherboard by sliding it upwards.
结论
另外一个人完成了本指南。
1指南评论
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
Ajen Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 676
