跳转到主内容
Heyday Round Bluetooth Speaker Motherboard Replacement
你所需要的
  1. Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: 步骤 1 中的图像 1,2 Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: 步骤 1 中的图像 2,2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 2 中的图像 1,3 Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 2 中的图像 2,3 Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  3. Heyday Round Bluetooth Speaker Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
  4. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 4 中的图像 1,2 Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
  5. Heyday Round Bluetooth Speaker Motherboard Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the motherboard by sliding it upwards.
结论
另外一个人完成了本指南。
一条评论
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
Ajen Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 34
总计 376
