跳转到主内容
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement
你所需要的
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: 步骤 1 中的图像 1,2 Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement, Hinges: 步骤 1 中的图像 2,2
    • Bend the headset so that you can see the 1.2mm screws that need to be removed before removing the hinge. Next, take a hold of a Philips screwdriver size 00 and remove the screws.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband. Replacement: 步骤 2 中的图像 1,1
    • After removing the two screws, you can replace the hinge by removing it from the wire.
结论
Christopher Puperi
于09/13/23注册
493 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 89
