跳转到主内容
Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement
你所需要的
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: 步骤 1 中的图像 1,2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: 步骤 1 中的图像 2,2
    • Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 步骤 2 中的图像 1,1
    • The connectors that the cushion snaps into place are used to attach the cushion to the headset. The connectors could be damaged by applying too much force, which would prevent the cushion from returning to its original position.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 步骤 3 中的图像 1,1
    • After the earpad cushion has been disconnected from the connectors you can take your new earpad cushion and install it.
  4. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • After removing the ear pad cushion, unscrew the four 1.6mm black screws with your Phillips-head screwdriver.
  5. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 步骤 5 中的图像 1,2 Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips-head screwdriver to remove the black casing screws.
    • Lift the casing to see the battery.
  6. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: 步骤 6 中的图像 1,1
    • The central spherical piece of metal is the battery. Use the ifixit opening tool and pry open the battery in your direction to remove the battery.
结论
Christopher Puperi
于09/13/23注册
493 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 104
