跳转到主内容
Health o Meter HDR743 Power Supply Replacement
你所需要的
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: 步骤 1 中的图像 1,1
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: 步骤 2 中的图像 1,1
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: 步骤 3 中的图像 1,1
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: 步骤 4 中的图像 1,2 Health o Meter HDR743  Power Supply Replacement: 步骤 4 中的图像 2,2
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 126
