跳转到主内容
加入维修社区 - 创建账户
Headset Adjustment
你所需要的
  1. Headset Adjustment, Headset Adjustment: 步骤 1 中的图像 1,1
    • To start the adjustment process first loosen the stem steerer clamp bolts.
  2. Headset Adjustment: 步骤 2 中的图像 1,2 Headset Adjustment: 步骤 2 中的图像 2,2
    • If you feel a knocking sensation when pulling the front brake and rocking the handlebars forward and back, then the headset needs to be tightened.
    • Turning the handlebars 90 degrees and repeating the process can help to ensure that any knocking sensations are not coming from play within the brake mechanism.
  3. Headset Adjustment: 步骤 3 中的图像 1,2 Headset Adjustment: 步骤 3 中的图像 2,2
    • Torque the bearing preload adjustment bolt on your stem cap just enough so that the knocking goes away.
    • Torque required is usually in the 2-3nm range.
    • If the steering feels rough or sluggish after tightening down the headset bearing preload bolt when turning your handlebars from side to side, you’ve over-tightened the headset.
    • Back it off an eighth or a quarter of a turn and check it again by turning the handlebars from side to side and pulling the front brake and rocking the handlebars front to back to feel for any knocking.
  4. Headset Adjustment: 步骤 4 中的图像 1,1
    • If no amount of tightening eliminates the knocking, add a two or five millimeter spacer under your headset top cap to increase the available range of adjustment.
  5. Headset Adjustment: 步骤 5 中的图像 1,1
    • Once you get a smooth steering feel without any knocking when performing the front brake test, your done with the adjustment and it is time to tighten the stem steerer clamping bolts.
    • Align the stem with the front wheel and torque the steerer clamp bolts to the manufacturer’s recommended torque spec.
结论
Daniel Slusser
于07/21/14注册
349 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 204
