跳转到主内容
Headphone Jack
你所需要的
  1. Headphone Jack, Battery: 步骤 1 中的图像 1,1
    • Unplug laptop from adapter and all other devices.
  2. Headphone Jack: 步骤 2 中的图像 1,1
    • Flip the laptop over with battery facing you.
  3. Headphone Jack: 步骤 3 中的图像 1,2 Headphone Jack: 步骤 3 中的图像 2,2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Headphone Jack: 步骤 4 中的图像 1,1
    • Pull battery out.
  5. Headphone Jack, Keyboard: 步骤 5 中的图像 1,1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Headphone Jack: 步骤 6 中的图像 1,1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. Headphone Jack: 步骤 7 中的图像 1,1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. Headphone Jack: 步骤 8 中的图像 1,1
    • Remove keyboard wire by popping latch under blue plastic
  9. Headphone Jack, Case: 步骤 9 中的图像 1,1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. Headphone Jack: 步骤 10 中的图像 1,1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. Headphone Jack: 步骤 11 中的图像 1,1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. Headphone Jack: 步骤 12 中的图像 1,3 Headphone Jack: 步骤 12 中的图像 2,3 Headphone Jack: 步骤 12 中的图像 3,3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. Headphone Jack, Headphone Jack: 步骤 13 中的图像 1,1
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  14. Headphone Jack: 步骤 14 中的图像 1,1
    • Use plastic pry tool to lift up on headphone jack assembly
结论
Tyler Lirio
于02/13/18注册
93 声望
撰写一个指南
团队
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 201
