跳转到主内容
加入维修社区 - 创建账户
Headphone Jack Replacement
你所需要的
  1. Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Have all of the tools and parts ready for use.
  2. Headphone Jack Replacement: 步骤 2 中的图像 1,2 Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Cut off the old faulty headphone jack.
    • Use the wire strippers to strip off the outermost rubber sheathing to expose the individual cords inside.
    • Most headphones have 3 internal wires, sometimes 4.
  3. Headphone Jack Replacement: 步骤 3 中的图像 1,2 Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Unscrew the new headphone jack casing.
    • Separate the wires.
    • If you can have it held, it will be easier for working with the soldering iron.
  4. Headphone Jack Replacement: 步骤 4 中的图像 1,3 Headphone Jack Replacement: 步骤 4 中的图像 2,3 Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Begin adding solder to each of the contacts of the headphone jack.
    • Every so often wipe off the soldering iron on a piece of sponge/cloth.
    • Wipe off excess solder to keep it in good condition
  5. Headphone Jack Replacement: 步骤 5 中的图像 1,2 Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Take the casing and thread it to the wire, make sure to put it right way around.
    • Trim excess wire. (optional)
  6. Headphone Jack Replacement: 步骤 6 中的图像 1,3 Headphone Jack Replacement: 步骤 6 中的图像 2,3 Headphone Jack Replacement: 步骤 6 中的图像 3,3
    • Add solder to the ends of each of the wires.
    • Give it a few seconds to make sure it gets through the coating.
  7. Headphone Jack Replacement: 步骤 7 中的图像 1,3 Headphone Jack Replacement: 步骤 7 中的图像 2,3 Headphone Jack Replacement: 步骤 7 中的图像 3,3
    • Solder the wire to the headphone jack.
    • Make sure each wire goes to the right connector.
    • Red and white wires connect to the signal. The remaining one connects the ground connector.
  8. Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Use pliers to crimp the ground connection onto the wire to make it nice and secured.
  9. Headphone Jack Replacement: 步骤 9 中的图像 1,2 Headphone Jack Replacement: 步骤 9 中的图像 2,2
    • Wrap around the contacts with electric tape to prevent shorts.
    • Move up the outer casing and screw it to the jack with pliers.
  10. Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • Test the headphone by plugging it into device.
终点
2等其他人完成本指南。
Chi Chung Yung
于05/14/20注册
235 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 27
过去 30 天: 107
总计 958
