跳转到主内容
Haute42 S13 Button and Switch Replacement
你所需要的
  1. Haute42 S13 Button and Switch Replacement, Button Switch: 步骤 1 中的图像 1,1
    • Unplug the controller from any device it is connected to and make sure it is powered off.
  2. Haute42 S13 Button and Switch Replacement: 步骤 2 中的图像 1,3 Haute42 S13 Button and Switch Replacement: 步骤 2 中的图像 2,3 Haute42 S13 Button and Switch Replacement: 步骤 2 中的图像 3,3
    • Use a keycap puller to remove the keycap from its socket.
    • Avoid using excessive force to prevent damaging the device.
  3. Haute42 S13 Button and Switch Replacement: 步骤 3 中的图像 1,3 Haute42 S13 Button and Switch Replacement: 步骤 3 中的图像 2,3 Haute42 S13 Button and Switch Replacement: 步骤 3 中的图像 3,3
    • Use the keycap/switch puller to remove the switch from its socket.
    • Be careful not to damage the controller while removing the switch.
  4. Haute42 S13 Button and Switch Replacement: 步骤 4 中的图像 1,2 Haute42 S13 Button and Switch Replacement: 步骤 4 中的图像 2,2
    • Align the pins of the new switch with the holes in the socket and replace the switch.
    • You will feel the pins slide into place.
    • Do not press the switch in until you know you have aligned it correctly, doing so may damage the pins on the switch.
  5. Haute42 S13 Button and Switch Replacement: 步骤 5 中的图像 1,1
    • Use your finger to push the switch into place.
    • You should hear a click when it connects.
    • Try moving it to make sure it is firmly in place. It should not move at all when attached to the controller.
  6. Haute42 S13 Button and Switch Replacement: 步骤 6 中的图像 1,3 Haute42 S13 Button and Switch Replacement: 步骤 6 中的图像 2,3 Haute42 S13 Button and Switch Replacement: 步骤 6 中的图像 3,3
    • Align the cross on the keycap and the cross on the switch and gently press the keycap onto the switch.
    • Avoid applying excessive pressure to prevent damaging the new switch.
  7. Haute42 S13 Button and Switch Replacement: 步骤 7 中的图像 1,1
    • Take a look at the OLED input display on the controller while pressing it to check if the button is fully functional.
    • On the screen, the button should highlight itself and the input history should be displayed at the bottom. If it all works, congratulations! You have successfully replaced this button.
终点
2等其他人完成本指南。
Owen Santin
于02/01/25注册
175 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 127
总计 1,001
