简介
Replacing the DC motor requires you remove the back panel and light sensor circuit board. The most difficult part of this replacement is removing the clips holding the fur on to the back panel.
你所需要的
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Remove the 10mm Phillips #0 screw holding the circuit board in.
Gently lift out the circuit board.
Unscrew the four screws holding the motor housing in place.
Remove the motor housing.
Orient Furby with the beak facing right.
Locate the red DC motor connector.
Gently remove the connector using blunt and pointed tweezers.
7等其他人完成本指南。
10条评论
Hi. Where can I buy a replacement motor please?
Generic replacement motors are on Ebay. The one I got was RF-300CA
I could not find the exact motor.
Specs: 1.5-6 volt.
24.2mm x 12.4mm (24x12).
10 or 12mm long shaft x 2mm diameter.
.99 cents free shipping. Two weeks from China.
https://www.ebay.com/itm/RF-300CA-DC-1-5V-6V-815...
You will need to de-solder the little half-moon shaped control board off the bottom of the old motor. Crazy glue it to the bottom of the new motor. Then solder the the red wires together and black wires together. Then solder them to the board. The old motor had spikes sticking out the bottom to connect the control board. The generic replacement motors have wires instead. I searched the entire internet. I could not find the exact motor.
https://www.youtube.com/watch?v=6WWecJ_I... It’s in Spanish, but you’ll get the idea.
To get the ears off. Firmly twist and pull them…HARD.
Good luck.
And how do I disconnect the coil from the motor? Just pulling hard?
Ronkly -
Hi, I have a problem with my 2012 Furby, he can talk but doesn’t move and he turns off after a minute. I wanted to know if I should remplace the DC motor. Thanks!
FurbyLover - 回复
I have the same issue - did you try to replace the motor?
Our 2012 Furby does move only a little bit after waking up, can talk normally and then turns off suddenly, only to awake again. Batteries are fine obviously.
PC Papa -
Where can I find the original motor?
Hi. I have a question. If i buy this motor https://www.ebay.com/itm/1pcs-Solar-Moto... will i be able to just plug it in or i will still need to de-solder the little control board? (that half-moon thing)
