跳转到主内容
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
你所需要的
  1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: 步骤 1 中的图像 1,3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: 步骤 1 中的图像 2,3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: 步骤 1 中的图像 3,3
    • Find the removable panel at the bottom of the hand.
    • Use your finger to push upwards and open the panel.
    • Slide the panel off and separate it from the hand.
  2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 步骤 2 中的图像 1,2 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 步骤 2 中的图像 2,2
    • Remove the left-most battery by pushing down on the positive end and pulling it out.
    • Repeat this for the next two batteries.
  3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: 步骤 3 中的图像 1,1
    • Remove the screws within the gauntlet and surrounding the palm.
  4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 步骤 4 中的图像 1,1
    • Open the gauntlet carefully, as there are wires connecting both sides.
    • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
  5. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 步骤 5 中的图像 1,1
    • To replace the LED chip, remove the screw holding the chip in place.
  6. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: 步骤 6 中的图像 1,1
    • Ensure that the LED chip is in the correct area with the correct polarity.
    • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
结论
Jessica
于02/24/23注册
109 声望
撰写一个指南
团队
Marist, Team 1-3, Chaterdon Spring 2023 Marist, Team 1-3, Chaterdon Spring 2023 的会员
MARS-CHATERDON-S23S1G3
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 456
