跳转到主内容
加入维修社区 - 创建账户
Hasbro Furby 2012 Switch Replacement
你所需要的
  1. Hasbro Furby 2012 Switch Replacement, Outer Shell: 步骤 1 中的图像 1,3 Hasbro Furby 2012 Switch Replacement, Outer Shell: 步骤 1 中的图像 2,3 Hasbro Furby 2012 Switch Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
  2. Hasbro Furby 2012 Switch Replacement: 步骤 2 中的图像 1,3 Hasbro Furby 2012 Switch Replacement: 步骤 2 中的图像 2,3 Hasbro Furby 2012 Switch Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 driver to unscrew the eight 10mm screws.
    • Remove the base ring after unscrewing all the screws.
    • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
  3. Hasbro Furby 2012 Switch Replacement: 步骤 3 中的图像 1,2 Hasbro Furby 2012 Switch Replacement: 步骤 3 中的图像 2,2
    • Unhook the white ribbon from the tab on the base.
  4. Hasbro Furby 2012 Switch Replacement: 步骤 4 中的图像 1,3 Hasbro Furby 2012 Switch Replacement: 步骤 4 中的图像 2,3 Hasbro Furby 2012 Switch Replacement: 步骤 4 中的图像 3,3
    • Roll the Furby's fur downward.
    • Disconnect the now exposed red wire.
  5. Hasbro Furby 2012 Switch Replacement: 步骤 5 中的图像 1,3 Hasbro Furby 2012 Switch Replacement: 步骤 5 中的图像 2,3 Hasbro Furby 2012 Switch Replacement: 步骤 5 中的图像 3,3
    • Locate the two middle clips first.
    • Locate the two remaining clips on Furby's sides, they are opposite each other.
    • Orient the Furby upside down with the tail facing away from you.
  6. Hasbro Furby 2012 Switch Replacement: 步骤 6 中的图像 1,3 Hasbro Furby 2012 Switch Replacement: 步骤 6 中的图像 2,3 Hasbro Furby 2012 Switch Replacement: 步骤 6 中的图像 3,3
    • Insert a metal prying tool directly into the clip opening.
    • Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
    • Repeat the previous step to remove the remaining three clips.
  7. Hasbro Furby 2012 Switch Replacement: 步骤 7 中的图像 1,3 Hasbro Furby 2012 Switch Replacement: 步骤 7 中的图像 2,3 Hasbro Furby 2012 Switch Replacement: 步骤 7 中的图像 3,3
    • Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
    • Lift up on the fur covering until the face of the Furby is exposed.
  8. Hasbro Furby 2012 Switch Replacement: 步骤 8 中的图像 1,3 Hasbro Furby 2012 Switch Replacement: 步骤 8 中的图像 2,3 Hasbro Furby 2012 Switch Replacement: 步骤 8 中的图像 3,3
    • Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
    • Lift tape gently and peel back until the tape is nearly removed.
    • Do not pull on the yellow wire located on the opposite end of the tape.
  9. Hasbro Furby 2012 Switch Replacement: 步骤 9 中的图像 1,2 Hasbro Furby 2012 Switch Replacement: 步骤 9 中的图像 2,2
    • Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
    • Remove the 10mm screws with the Phillips#0 screwdriver.
  10. Hasbro Furby 2012 Switch Replacement: 步骤 10 中的图像 1,1
    • Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
    • Peel the tape up until it is nearly detached from the black case.
  11. Hasbro Furby 2012 Switch Replacement: 步骤 11 中的图像 1,2 Hasbro Furby 2012 Switch Replacement: 步骤 11 中的图像 2,2
    • Orient the Furby face down, with the base facing away from you.
    • Locate the clips below the ears.
    • Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
  12. Hasbro Furby 2012 Switch Replacement: 步骤 12 中的图像 1,2 Hasbro Furby 2012 Switch Replacement: 步骤 12 中的图像 2,2
    • Remove the loose, plastic back panel by pulling the panel away from Furby's body.
  13. Hasbro Furby 2012 Switch Replacement, Switch: 步骤 13 中的图像 1,2 Hasbro Furby 2012 Switch Replacement, Switch: 步骤 13 中的图像 2,2
    • Locate and remove the two screws holding in the switch using J0 Phillips Head Screw Driver.
  14. Hasbro Furby 2012 Switch Replacement: 步骤 14 中的图像 1,2 Hasbro Furby 2012 Switch Replacement: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    • Orient the Furby with the beak facing right.
    • Using the blunt and pointed tweezers, remove the black connector.
    • Insert the new switch in place of where the previous connector was located.
结论
2等其他人完成本指南。
Jordan Castillo
于10/06/16注册
1,048 声望
创作了5篇指南
团队
Cal Poly, Team 15-5, Livingston Fall 2016 Cal Poly, Team 15-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G5
4 名成员
创作了10篇指南
1指南评论
Did someone find a replacement furby switch? Or found a way to repair the one inside the furby already?
Frubyx - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 36
总计 1,832
