跳转到主内容
Hasbro Bop-It Micro Series Levers Replacement
你所需要的
  1. Hasbro Bop-It Micro Series Levers Replacement, Back Case: 步骤 1 中的图像 1,1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Levers Replacement: 步骤 2 中的图像 1,1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Levers Replacement: 步骤 3 中的图像 1,1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Levers Replacement, Levers: 步骤 4 中的图像 1,1
    • Observe the orientation of the levers before removal.
    • Remove the white plastic levers with your fingers.
结论
2等其他人完成本指南。
Glenn Haag
于09/29/16注册
479 声望
创作了3篇指南
团队
IUPUI, Team 3-1, Harley Fall 2016 IUPUI, Team 3-1, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 1,926
