跳转到主内容
Harman Kardon Onyx Studio 2 Speakers Replacement
你所需要的
  1. Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: 步骤 1 中的图像 1,3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: 步骤 1 中的图像 2,3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - 回复
    If I take this off can I put it back on
    Burger King - 回复
  2. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 2 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - 回复
    Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
    Eduardo Heine - 回复
    Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
    Joe Lim - 回复
  3. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 3 中的图像 1,1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 4 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
    Please can I get a replacement of my panel to the phone
    Chinedu Ogunedo - 回复
  5. Harman Kardon Onyx Studio 2 Speakers Replacement, Control Board: 步骤 5 中的图像 1,1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 6 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 6 中的图像 2,2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 7 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 7 中的图像 2,2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
    From where to buy Control panel
    ali - 回复
    From where to buy this control panel
    ali - 回复
  8. Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: 步骤 8 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: 步骤 8 中的图像 2,2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 9 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 9 中的图像 2,2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
    I own two of these and the both shut down on their own.. where do I buy the replacement boards from?
    Darren Vincent - 回复
  10. Harman Kardon Onyx Studio 2 Speakers Replacement, Speakers: 步骤 10 中的图像 1,1
    • Using the metal spudger, gently pry off the two red and black connectors.
  11. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 11 中的图像 1,2 Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 11 中的图像 2,2
    • Remove the four 14.3 mm T10 Torx screws.
  12. Harman Kardon Onyx Studio 2 Speakers Replacement: 步骤 12 中的图像 1,1
    • Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
    Please attach a link where best to buy parts/speakers for this model. I found your step by step instructions very well detailed except for the source of parts
    Bernard Rocha - 回复
结论
7等其他人完成本指南。
团队
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G5
3 名成员
创作了24篇指南
2条评论
Hi, do anyone know sparepart number for woofer elements?
Mikko Lehto - 回复
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
James Santiago - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 87
总计 19,489
