跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Harman Kardon Onyx Studio 2 Front Panel Replacement
你所需要的
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: 步骤 1 中的图像 2,3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - 回复
    If I take this off can I put it back on
    Burger King - 回复
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: 步骤 2 中的图像 1,2 Harman Kardon Onyx Studio 2 Front Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - 回复
    Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
    Eduardo Heine - 回复
    Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
    Joe Lim - 回复
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: 步骤 3 中的图像 1,1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: 步骤 4 中的图像 1,2 Harman Kardon Onyx Studio 2 Front Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
    Please can I get a replacement of my panel to the phone
    Chinedu Ogunedo - 回复
结论
To reassemble, follow these steps in reverse order.
2等其他人完成本指南。
团队
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G5
3 名成员
创作了24篇指南
一条评论
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 57
总计 6,091
