跳转到主内容
Harman Kardon Onyx Studio 2 Control Board Replacement
你所需要的
  1. Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: 步骤 1 中的图像 1,3 Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: 步骤 1 中的图像 2,3 Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 2 中的图像 1,2 Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 2 中的图像 2,2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 3 中的图像 1,1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 4 中的图像 1,2 Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 4 中的图像 2,2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Control Board Replacement, Control Board: 步骤 5 中的图像 1,1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 6 中的图像 1,2 Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 6 中的图像 2,2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 7 中的图像 1,2 Harman Kardon Onyx Studio 2 Control Board Replacement: 步骤 7 中的图像 2,2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G5
3 名成员
创作了24篇指南
9条评论
Do you guys know where to get a control board, because my board is broken so i am looking for one
Zhou Yuqi - 回复
Where to get control board onyx 2.
Mike Champagne - 回复
My on/off button keeps blinking…..would somebody please email me cause I am a techno nitwit……..i’m gonna bring this piece of non chargeable crap outside and go Italian on it with the 12 gauge! SERENITY NOW!
Sincerely,
email ; jorcal3318@aol.com
Frank Vitolo - 回复
power button continually blinks. Won’t turn on, can’t pair, no other action can be taken, just the blinking power button. what’s the solution? Please share….
rachael friesen -
Speaker plays for split second then fades away like wtf
Paul Berrellez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 50
总计 14,315
