当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the five 14.4 mm T10 Torx screws.
Gently pull the front apart from the back.
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Pull the silicone button band off of the outer edge of the speaker.
Disconnect the two pressure connections from the circuit board.
Gently remove the control board band by placing fingers in contact with it through the button openings.
Work from the outer edges in so as not to bend the band.
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Remove the four 10 mm T10 Torx screws.
Pull the circuit board out of the device as it is now free.
Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board.
Peel off completely and remove from the device.
取消:我没有完成这个指南。
4等其他人完成本指南。
与1其他贡献者
于02/02/17注册
2,046 声望
创作了6篇指南
徽章: 16
+ 13更多徽章
USFT-BLACKWELL-S17S16G5
3 名成员
创作了24篇指南
Any idea where we can purchase the replacement parts?
Cort Krause - 2018年2月19日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 35
总计 9,485
