跳转到主内容
简介
After removing the control board and circuit board, the Bluetooth antenna can be accessed and therefore removed. This is helpful if a lack of Bluetooth connectivity is due to the speaker.
  1. Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device. Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device. Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - 回复
    If I take this off can I put it back on
    Burger King - 回复
  2. Remove the five 14.4 mm T10 Torx screws. Remove the five 14.4 mm T10 Torx screws.
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - 回复
  3. Gently pull the front apart from the back.
    • Gently pull the front apart from the back.
  4. Remove the four wires connecting the front and back panels. Pinch the connector tab and pull gently upwards.
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Pull the silicone button band off of the outer edge of the speaker.
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Disconnect the two pressure connections from the circuit board. Disconnect the two pressure connections from the circuit board.
    • Disconnect the two pressure connections from the circuit board.
  7. Gently remove the control board band by placing fingers in contact with it through the button openings. Work from the outer edges in so as not to bend the band.
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
    From where to buy Control panel
    ali - 回复
    From where to buy this control panel
    ali - 回复
  8. Disconnect the remaining connectors from the circuit board. Disconnect the Bluetooth antenna.
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Remove the four 10 mm T10 Torx screws. Pull the circuit board out of the device as it is now free.
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
  10. Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board. Peel off completely and remove from the device.
    • Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board.
    • Peel off completely and remove from the device.
    I was wondering if you guys have this bluetooth antenna available for sale.
    Thank you
    Julio Dávila - 回复
结论
2等其他人完成本指南。
Alexandra Achtenberg
于2017年02月02日注册
1,736 信誉积分
创作了6篇指南
团队
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G5
3 名成员
创作了24篇指南
一条评论
Any idea where we can purchase the replacement parts?
Cort Krause - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 10
过去的30天: 46
总计 8,307
