跳转到主内容
Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's
你所需要的
  1. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's, Front Panel: 步骤 1 中的图像 1,1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's: 步骤 2 中的图像 1,1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's, Buttons and Charging Indicator Lights's: 步骤 3 中的图像 1,1
    • The buttons will be on the side of the device, use the plastic opening tool to remove it from its actual place no need to use any screwdrivers.
  4. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to remove the indicator lights and replace them by new ones.
结论
yousef aljeemaz
于10/18/17注册
1,039 声望
创作了5篇指南
团队
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G9
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 21
总计 1,464
