跳转到主内容
Harman Kardon Esquire Mini Battery Replacement
你所需要的
  1. Harman Kardon Esquire Mini Battery Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Battery Replacement: 步骤 2 中的图像 1,1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • After removing the front panel, remove the battery from its plug using a small amount of force.
    • Do not to break the battery plug, be gentle.
  4. Harman Kardon Esquire Mini Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by using a plastic opening tool, by applying an upward force.
    • Be careful to not tear the electric wires.
结论
4等其他人完成本指南。
yousef aljeemaz
于10/18/17注册
1,039 声望
创作了5篇指南
团队
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G9
5 名成员
创作了5篇指南
4条评论
Between steps 3 and 4 I needed to disconnect the red speaker cable (right speaker step 4 image). I can see you didn't need to. The cable came out and returned to a socket.
Antony Cartwright - 回复
Where do I get a new battery?
Dennis Easter - 回复
I was able to follow this guide to disassemble my Harman/Kardon Esquire 2 speaker to also replace the battery, which had dropped to only holding about 20m charge.
Process is almost identical, just a bigger unit/speaker.
The battery in this unit was a "GSP805070" 3.7V 3200mAh, 11.84Wh Lithium Polymer, this had swollen to nearly double its thickness.
I was able to find a 3500mAh replacement on eBay.
anonymuchacho - 回复
Between steps 2 and 3, you have to unscrew the motherboard to get to the battery. Also, there is a bead of (probably) waterproofing glue holding things together. Just be gentle and careful, and the repair is doable with some skill. Not something for the total novice to attempt, but without this guide I would probably would not have repaired this unit, which was given to me as a gift, but had been in the original box for a number of years and was dead on opening. Thanks for the guide!
Bob McNabb - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 54
总计 6,802
