简介
This guide will show how to remove the old spark plugs, check the new spark plugs for installation, prepare the spark plugs for installation, and reinstall the new spark plugs.
你所需要的
Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire.
Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches (1.016mm).
Using your fingers, install the new spark plug into the socket, and hand tighten until firm.
Using a torque wrench, tighten the spark plug to the proper specification.
Questions.1 with a stage 1,2 or 3 would you agree a wider gap? 2nd question which is simular to first.i do run my motor a little rich.rather rich than lean.my question is with modification on a harley davidson sportster.what do ou recommend.so many choices from om to iridium to platinum.then the gap and also are you a believer in cutting the eledtrode approx half off for max combustion.how much would you recommend cutting and back to og question.the gap.is a larger gap.capable of power increase.since ive tried both i swear i feel a power increase.but is it anticipated or other varibles???you opinion is valued.
Reinstall your spark plug wire by pushing it firmly onto the new plug.
I have a Harley Davidson Xr1200x Sportster which I just got. Changed the oil also tranny & filter as I couldn't find last date of service coang of oil. So yesterday I checked the spark plugs they were clean. But the mechanic cleaned them & said the needed gap them as one was too narrow. Mind you I had no issues at all. Gapped them at 0.40 now I'm not getting the same smooth sound or feel as if it's miss firing. I have iridium spark plugs okn my bike should I change them to NGK or get another set of iridium spark plugs.please advise..
A spark plug Gap is to be checked with a wire feeler gauge, not a flat feeler gauge….
Which wires go to which plug
Be sure to repeat the above procedure for the remaining cylinder.
20等其他人完成本指南。
8条评论
Couldn't have made it any simpler
-awesome
- appreciated
Thank you so much for your posting. I'm 2k miles from my daughter who is teaching herself how to maintain her own bike. You site is immensely helpful and appreciated as much.
Says between 11 and 18 pounds in manuel
Is there a firing order like on a car I'm just trying to make sure I have the rite plug with the rite plug wire
I really appreciate your site…thank you.
lori milne - 回复
Can anyone tell me if a 1999 sporster has a data link connector port . my bike would not start the coil was bad replaced it now no spark at all can anyone help
