跳转到主内容
Hard Reset
  1. Hard Reset, Hard Reset: 步骤 1 中的图像 1,1
    • With the phone powered off, press and hold the Talk/Send, End, and Power buttons (the 3 circled here) for about 3 seconds.
  2. Hard Reset: 步骤 2 中的图像 1,2 Hard Reset: 步骤 2 中的图像 2,2
    • When the screen powers on, you will see an instructional message.
    • Press the volume up button to perform the hard reset.
    • The hard reset will erase all personal data on your device. If you would like to cancel the hard reset, press any other button.
  3. Hard Reset: 步骤 3 中的图像 1,1
    • Your device will display this screen after a few seconds. Press the Volume Up button to boot your phone.
  4. Hard Reset: 步骤 4 中的图像 1,2 Hard Reset: 步骤 4 中的图像 2,2
    • Your phone will display this screen. If you would like to import your SIM contacts now, tap "Import SIM contacts" and tap "Next". Otherwise, tap "Cancel".
结论
You have just performed a hard reset on your HTC Fortress. All personal data on your phone has been deleted, and your phone is now back to its default settings.
7等其他人完成本指南。
Lucas David
于04/19/13注册
540 声望
创作了9篇指南
团队
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G13
4 名成员
创作了18篇指南
一条评论
great information thanks.
regards
Jrubio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 2,523
