跳转到主内容
Hard Drive Removal
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Hard Drive Removal, Remove the hard drive cover: 步骤 1 中的图像 1,3 Hard Drive Removal, Remove the hard drive cover: 步骤 1 中的图像 2,3 Hard Drive Removal, Remove the hard drive cover: 步骤 1 中的图像 3,3
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. Hard Drive Removal, Remove the hard drive bracket screw: 步骤 2 中的图像 1,2 Hard Drive Removal, Remove the hard drive bracket screw: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. Hard Drive Removal, Remove the hard drive bracket: 步骤 3 中的图像 1,3 Hard Drive Removal, Remove the hard drive bracket: 步骤 3 中的图像 2,3 Hard Drive Removal, Remove the hard drive bracket: 步骤 3 中的图像 3,3
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
结论
Sam Omiotek
于02/25/19注册
72,547 声望
创作了288篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 117
