跳转到主内容
Hannspree SN12E2 Touchpad Plane/Keyboard Replacement
你所需要的
  1. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 2 中的图像 1,1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 3 中的图像 1,3 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 3 中的图像 2,3 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 3 中的图像 3,3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement, Touchpad Plane/Keyboard: 步骤 4 中的图像 1,1
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 5 中的图像 1,3 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 5 中的图像 2,3 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 5 中的图像 3,3
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 6 中的图像 1,2 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 6 中的图像 2,2
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: 步骤 7 中的图像 1,1
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
结论
Tim Chase
于03/25/19注册
360 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 164
