跳转到主内容
Hannspree SN12E2 RAM Replacement
你所需要的
  1. Hannspree SN12E2 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 RAM Replacement: 步骤 2 中的图像 1,1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 RAM Replacement: 步骤 3 中的图像 1,3 Hannspree SN12E2 RAM Replacement: 步骤 3 中的图像 2,3 Hannspree SN12E2 RAM Replacement: 步骤 3 中的图像 3,3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 RAM Replacement, RAM: 步骤 4 中的图像 1,2 Hannspree SN12E2 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Remove the RAM access door.
    • Remove the two 3mm screws using a Phillips #0 screwdriver.
    • Gently lift on the door out of place.
    • When replacing the door it should click into place. Ensure the alignment tabs are correctly seated and gently push until it clicks into place.
  5. Hannspree SN12E2 RAM Replacement: 步骤 5 中的图像 1,3 Hannspree SN12E2 RAM Replacement: 步骤 5 中的图像 2,3 Hannspree SN12E2 RAM Replacement: 步骤 5 中的图像 3,3
    • Gently push outward on the two retaining clips, being careful not to damage the motherboard.
    • Lift up on the RAM until it makes a 35 degree angle with the board.
    • Remove the RAM by pulling away from the housing at 35 degrees.
结论
另外一个人完成了本指南。
Tim Chase
于03/25/19注册
360 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 263
