跳转到主内容
Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement
你所需要的
  1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 2 中的图像 1,2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 3 中的图像 1,1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 4 中的图像 1,2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 4 中的图像 2,2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 5 中的图像 1,2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 5 中的图像 2,2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: 步骤 6 中的图像 1,2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 7 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 7 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 7 中的图像 3,3
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 8 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 8 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 8 中的图像 3,3
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 9 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 9 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 9 中的图像 3,3
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: 步骤 10 中的图像 1,2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: 步骤 10 中的图像 2,2
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 11 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 11 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 11 中的图像 3,3
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 12 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 12 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 12 中的图像 3,3
    • Pull the cameras out of their resting places in a straight upward motion.
  13. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: 步骤 13 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: 步骤 13 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: 步骤 13 中的图像 3,3
    • Identify the speakers.
    • Use a pair of tweezers to peel the adhesive tape holding the speaker wires down.
  14. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 14 中的图像 1,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 14 中的图像 2,3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 14 中的图像 3,3
    • Desolder the red and black wire to the left and the right of the ZIF connector.
    • Remember the placement of both wires.
    • Both the soldering iron and the wires will be hot.
  15. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 15 中的图像 1,2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: 步骤 15 中的图像 2,2
    • Remove the right and left speaker.
结论
另外一个人完成了本指南。
团队
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S9G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 423
