跳转到主内容
Hannspree Hannspad SN1AT71 Back Panel Replacement
你所需要的
  1. Hannspree Hannspad SN1AT71 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 2 中的图像 1,2 Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 3 中的图像 1,1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 4 中的图像 1,2 Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 4 中的图像 2,2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 5 中的图像 1,2 Hannspree Hannspad SN1AT71 Back Panel Replacement: 步骤 5 中的图像 2,2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
结论
4等其他人完成本指南。
团队
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S9G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 17
总计 2,381
