跳转到主内容
HannStar HN198 Monitor Main and Power Board Capacitors Replacement
你所需要的
  1. HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Opening the monitor: 步骤 1 中的图像 1,3 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Opening the monitor: 步骤 1 中的图像 2,3 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Opening the monitor: 步骤 1 中的图像 3,3
    • Before you begin, be sure to unplug the device from the outlet.
    • WARNING: There are capacitors inside that can pose a serious shock hazard. Be very careful not to touch any exposed leads on the power board.
    • First of all, you need to unscrew the 4 screws holding the stand. After that the 4 screws holding the back panel, they are located in the corners of the device (only the top ones are shown in the picture).
    • Second, you need to pry the plastic grey basel on the front of the monitor. There are several clips holding everything together.
    • Also after removing the basel it might be a good idea to give the screen a good clean.
  2. HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Reaching the power and main boards.: 步骤 2 中的图像 1,3 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Reaching the power and main boards.: 步骤 2 中的图像 2,3 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Reaching the power and main boards.: 步骤 2 中的图像 3,3
    • First of all, disconnect all the connectors (5 marked with arrows.)
    • Second, remove the 4 acrews holding the bracket, marked with blue. (Also there might be some aluminum tape holding the covers, just rip it off, you wont need it for reassembly)
    • Third, remove the 4 screws covering the boards, marked with red.
  3. HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Checking the power board: 步骤 3 中的图像 1,2 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Checking the power board: 步骤 3 中的图像 2,2
    • After opening the cover, remove the 4 screws holding the power board and check for busted capacitors. (You might need to disconnect the connector, it might be easier for you to work)
    • In my case I had to change the 7 capacitors marked in red (the picture is after the change).
    • You can always put higher voltage (V) rated capacitors (if you have the space), but dont change the farad (F) rating.
  4. HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Checking the main board: 步骤 4 中的图像 1,3 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Checking the main board: 步骤 4 中的图像 2,3 HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Checking the main board: 步骤 4 中的图像 3,3
    • Remove the 3 screws holding the main board and disconnect the 2 connectors
    • Unscrew the monitor connector stands so you can remove the board.
    • Flip the board and inspect the capacitors. In my case they were all fine (except the one marked in blue) and the monitor was working after I changed the capacitors on the power board, but yours may be different.
  5. HannStar HN198 Monitor Main and Power Board Capacitors Replacement, Final: 步骤 5 中的图像 1,1
    • After putting everything back together, the monitor was working once again. I tested both display ports and the AUX port.
    • If fixing the capacitors didnt resolve your problem, please leave a comment.
    • Thank you for following my guide and I hope it helped you!
结论
2等其他人完成本指南。
Simeon Brankov
于11/08/20注册
6,045 声望
创作了51篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 321
