跳转到主内容
加入维修社区 - 创建账户
Handspring Visor Edge Speaker Replacement
你所需要的
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: 步骤 1 中的图像 1,2 Handspring Visor Edge Speaker Replacement, Flip Cover: 步骤 1 中的图像 2,2
    • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
    • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
    • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
    • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: 步骤 4 中的图像 1,2 Handspring Visor Edge Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: 步骤 5 中的图像 1,2 Handspring Visor Edge Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: 步骤 8 中的图像 1,1
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: 步骤 9 中的图像 1,1
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
结论
Nick Lazarakis
于01/23/11注册
334 声望
创作了3篇指南
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 57
总计 1,108
