跳转到主内容
Handspring Visor Edge Speaker Replacement
你所需要的
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: 步骤 1 中的图像 1,2 Handspring Visor Edge Speaker Replacement, Flip Cover: 步骤 1 中的图像 2,2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: 步骤 4 中的图像 1,2 Handspring Visor Edge Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: 步骤 5 中的图像 1,2 Handspring Visor Edge Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: 步骤 8 中的图像 1,1
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: 步骤 9 中的图像 1,1
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: 步骤 10 中的图像 1,1
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
结论
Nick Lazarakis
于01/23/11注册
331 声望
创作了3篇指南
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 792
