跳转到主内容
Handspring Visor Edge Flip Cover Spring Replacement
你所需要的
  1. Handspring Visor Edge Flip Cover Spring Replacement, Flip Cover: 步骤 1 中的图像 1,2 Handspring Visor Edge Flip Cover Spring Replacement, Flip Cover: 步骤 1 中的图像 2,2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Flip Cover Spring Replacement, Flip Cover Spring: 步骤 2 中的图像 1,1
    • Once flip cover is removed, turn over and remove the four 3.9 mm screws connecting the hinge.
  3. Handspring Visor Edge Flip Cover Spring Replacement: 步骤 3 中的图像 1,2 Handspring Visor Edge Flip Cover Spring Replacement: 步骤 3 中的图像 2,2
    • Gently pull away the plastic hinge from the cover.
    • Be careful to pull out evenly and not bend the plastic, as it can crack.The spring may also shoot out if it is not pulled out evenly.
  4. Handspring Visor Edge Flip Cover Spring Replacement: 步骤 4 中的图像 1,1
    • Turn the hinge piece on its side or use a screwdriver to pull out the spring.
    • Reinsert new spring.
结论
Blaize Steiger
于01/30/11注册
101 声望
撰写一个指南
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,105
