跳转到主内容
Handspring Visor Edge Flip Cover Replacement
  1. Handspring Visor Edge Flip Cover Replacement, Flip Cover: 步骤 1 中的图像 1,2 Handspring Visor Edge Flip Cover Replacement, Flip Cover: 步骤 1 中的图像 2,2
    • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
    • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
    • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
    • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
结论
To reassemble, follow step backwards.
另外一个人完成了本指南。
Joey Lyman
于01/23/11注册
119 声望
撰写一个指南
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 743
