跳转到主内容
Handspring Visor Edge Button Board Replacement
你所需要的
  1. Handspring Visor Edge Button Board Replacement, Flip Cover: 步骤 1 中的图像 1,2 Handspring Visor Edge Button Board Replacement, Flip Cover: 步骤 1 中的图像 2,2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Button Board Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Button Board Replacement: 步骤 3 中的图像 1,1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Button Board Replacement: 步骤 4 中的图像 1,2 Handspring Visor Edge Button Board Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Button Board Replacement: 步骤 5 中的图像 1,2 Handspring Visor Edge Button Board Replacement: 步骤 5 中的图像 2,2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Button Board Replacement: 步骤 6 中的图像 1,1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Button Board Replacement, Button Board: 步骤 7 中的图像 1,1
    • Pull off front cover gently.
  8. Handspring Visor Edge Button Board Replacement: 步骤 8 中的图像 1,1
    • Remove buttons by hand, they should come off easily.
结论
Nick Lazarakis
于01/23/11注册
331 声望
创作了3篇指南
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 754
