跳转到主内容
Handspring Visor Edge Battery Replacement
你所需要的
  1. Handspring Visor Edge Battery Replacement, Flip Cover: 步骤 1 中的图像 1,2 Handspring Visor Edge Battery Replacement, Flip Cover: 步骤 1 中的图像 2,2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Battery Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Battery Replacement: 步骤 4 中的图像 1,2 Handspring Visor Edge Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Battery Replacement: 步骤 5 中的图像 1,2 Handspring Visor Edge Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Battery Replacement: 步骤 6 中的图像 1,1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Gently pull off the front cover.
  8. Handspring Visor Edge Battery Replacement: 步骤 8 中的图像 1,2 Handspring Visor Edge Battery Replacement: 步骤 8 中的图像 2,2
    • Gently use your finger or tweezers to push the brown lock away from the side of the circuit board that is holding the ribbon cable.
    • Remove the ribbon cable with tweezers.
  9. Handspring Visor Edge Battery Replacement: 步骤 9 中的图像 1,1
    • Using the tweezers, pull back the ribbon cable on the top of the device.
    • Pull at the white part of the ribbon to avoid tearing.
  10. Handspring Visor Edge Battery Replacement: 步骤 10 中的图像 1,1
    • Using the same technique as with the other ribbons, locate and disconnect the ribbon cable above the battery pack.
  11. Handspring Visor Edge Battery Replacement: 步骤 11 中的图像 1,1
    • All the ribbon cables should be disconnected from the mother board.
    • Remove the four 3.6 mm Phillips #00 screws located at each corner of the device.
  12. Handspring Visor Edge Battery Replacement: 步骤 12 中的图像 1,2 Handspring Visor Edge Battery Replacement: 步骤 12 中的图像 2,2
    • Carefully separate the circuit board and the screen. (Be careful of soldered wires when separating)
    • Be careful not to break the soldered wires that connects the circuit board to the battery pack.
    • Disconnect the wire that connects the battery pack to the motherboard using tweezers.
  13. Handspring Visor Edge Battery Replacement: 步骤 13 中的图像 1,2 Handspring Visor Edge Battery Replacement: 步骤 13 中的图像 2,2
    • Wedge the spudger under the battery to pry it apart from the adhesive.
结论
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 24
总计 3,141
