跳转到主内容
简介
The only tool needed is a #00 Phillips Screw driver.
配件
没有特定配件。
  1. Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  2. Remove the black plate from the PDA.
    • Remove the black plate from the PDA.
  3. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  4. Remove four 2.6 mm Philips screws that are on the sides of the frame. Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
    • Remove four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
  5. Remove the four 2.6 mm Philips screws on the top and bottom of the frame. Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Remove the white frame from the PDA.
    • Remove the white frame from the PDA.
    • The frame may get stuck on the corners so be very gentle when working the corners off.
结论
另外一个人完成了本指南。
Nick Lazarakis
于2011年01月23日注册
334 信誉积分
创作了3篇指南
团队
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 912
