跳转到主内容
Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement
你所需要的
  1. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: 步骤 1 中的图像 1,2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: 步骤 1 中的图像 2,2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 2 中的图像 1,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 2 中的图像 2,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 2 中的图像 3,3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 3 中的图像 1,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 3 中的图像 2,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 3 中的图像 3,3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: 步骤 4 中的图像 1,2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: 步骤 4 中的图像 2,2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 5 中的图像 1,1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Back Cover: 步骤 6 中的图像 1,1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 7 中的图像 1,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 7 中的图像 2,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 7 中的图像 3,3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 8 中的图像 1,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 8 中的图像 2,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 8 中的图像 3,3
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Button Pad and Battery Terminal: 步骤 9 中的图像 1,1
    • Use tweezers to remove the power button from the back case.
  10. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 10 中的图像 1,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 10 中的图像 2,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 10 中的图像 3,3
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
  11. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: 步骤 11 中的图像 1,2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: 步骤 11 中的图像 2,2
    • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  12. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 12 中的图像 1,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 12 中的图像 2,3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 步骤 12 中的图像 3,3
    • Use the spudger to lift the motherboard from the case.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 1-2, Regan SU 2012 Cal Poly, Team 1-2, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,059
