当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the outer screen cover by releasing the top clip from the main body of the device.
Pull out the stylus from the top right corner of the device.
Slide the memory cartridge cover up and off the device.
Remove the battery cover by releasing the clip from the main body of the device.
Remove the batteries from the device.
Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
Be careful while opening the casing as there is a flex strip connecting the two halves.
Disconnect the flex strip from the motherboard with tweezers.
Use tweezers to remove the power button from the back case.
Disconnect the button pad by using the spudger to pry it off the motherboard.
Remove the button pad.
取消:我没有完成这个指南。
与6其他贡献者
于06/20/12注册
19 声望
创作了5篇指南
徽章: 8
+ 5更多徽章
CPSU-REGAN-SU12S1G2
4 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 641
