跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will walk you through how to replace your button pad.
  1. Remove the outer screen cover by releasing  the top clip from the main body of the device. Remove the outer screen cover by releasing  the top clip from the main body of the device.
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device.
    • Pull out the stylus from the top right corner of the device.
  3. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device.
    • Slide the memory cartridge cover up and off the device.
  4. Remove the battery cover by releasing the clip from the main body of the device. Remove the battery cover by releasing the clip from the main body of the device.
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. 基本电子产品工具包
    小工具包。却有无限可能。
    Shop Toolkits
    基本
    电子产品
    工具包
    Shop Toolkits
  6. Remove the batteries from the device.
    • Remove the batteries from the device.
  7. Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  8. Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device. Be careful while opening the casing as there is a flex strip connecting the two halves. Be careful while opening the casing as there is a flex strip connecting the two halves.
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  9. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers.
    • Disconnect the flex strip from the motherboard with tweezers.
  10. Use tweezers to remove the power button from the back case.
    • Use tweezers to remove the power button from the back case.
  11. Disconnect the button pad by using the spudger to pry it off the motherboard. Remove the button pad. Remove the button pad.
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
结论
David Faltemier
于2012年06月20日注册
19 信誉积分
创作了5篇指南
团队
Cal Poly, Team 1-2, Regan SU 2012 Cal Poly, Team 1-2, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G2
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 464
