跳转到主内容
Handset Speaker Replacement
你所需要的
  1. Handset Speaker Replacement, Handset: 步骤 1 中的图像 1,1
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  2. Handset Speaker Replacement: 步骤 2 中的图像 1,2 Handset Speaker Replacement: 步骤 2 中的图像 2,2
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  3. Handset Speaker Replacement: 步骤 3 中的图像 1,2 Handset Speaker Replacement: 步骤 3 中的图像 2,2
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
  4. Handset Speaker Replacement, Handset Speaker: 步骤 4 中的图像 1,1
    • After disassembling the handset, you will see a circular component at the top section of the handset. This is your speaker.
    • Use a screwdriver to remove the three 7mm Phillips #0 screws holding the speaker in place.
  5. Handset Speaker Replacement: 步骤 5 中的图像 1,1
    • Gently pull out the speaker and inspect it.
    • Determine if the handset speaker is damaged and needs replaced. Replacement requires soldering.
    • Finish removing a faulty speaker by cutting the two wires connecting it to the circuit board.
  6. Handset Speaker Replacement: 步骤 6 中的图像 1,1
    • Solder the replacement speaker in the circuit board. For information on how-to-solder check iFixit's Solder and Desolder Guide by clicking the blue link below.
结论
Han Shih
于09/29/16注册
361 声望
创作了4篇指南
团队
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G3
4 名成员
创作了17篇指南
一条评论
What shall I look for speaker is not working?
naila ilyas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 701
