跳转到主内容
加入维修社区 - 创建账户
Handset Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Handset Replacement, Battery: 步骤 1 中的图像 1,2 Handset Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the battery cover by placing your thumb on the cover and gently push towards the base of the phone.
  2. Handset Replacement: 步骤 2 中的图像 1,1
    • Remove the rechargeable battery pack (BP-T18) by pressing down on the power cable connector and pulling at the same time.
  3. Handset Replacement, Handset: 步骤 3 中的图像 1,1
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  4. Handset Replacement: 步骤 4 中的图像 1,2 Handset Replacement: 步骤 4 中的图像 2,2
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  5. Handset Replacement: 步骤 5 中的图像 1,2 Handset Replacement: 步骤 5 中的图像 2,2
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
结论
Caleb Thomas
于09/29/16注册
161 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G3
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 92
