跳转到主内容
Handheld Toilet Bidet Sprayer Replacement
你所需要的
  1. Handheld Toilet Bidet Sprayer Replacement, Handheld Toilet Bidet Sprayer: 步骤 1 中的图像 1,1
    • Turn off the toilet water valve by turning the knob clockwise.
  2. Handheld Toilet Bidet Sprayer Replacement: 步骤 2 中的图像 1,1
    • Flush the toilet until no water is left in the tank.
  3. Handheld Toilet Bidet Sprayer Replacement: 步骤 3 中的图像 1,1
    • Place a towel under the tank incase of any water drops.
  4. Handheld Toilet Bidet Sprayer Replacement: 步骤 4 中的图像 1,1
    • Unscrew the water supply line from the T-connector by turning the knob counterclockwise.
  5. Handheld Toilet Bidet Sprayer Replacement: 步骤 5 中的图像 1,1
    • Unscrew the hose from the T-connector by turning the knob counterclockwise.
  6. Handheld Toilet Bidet Sprayer Replacement: 步骤 6 中的图像 1,1
    • Unscrew the T-connector from the toilet by turning the knob counterclockwise.
  7. Handheld Toilet Bidet Sprayer Replacement: 步骤 7 中的图像 1,3 Handheld Toilet Bidet Sprayer Replacement: 步骤 7 中的图像 2,3 Handheld Toilet Bidet Sprayer Replacement: 步骤 7 中的图像 3,3
    • Install the toilet sprayer's rubber on the water supply hose from the side that is causing a water leak. This will stop water leaking from the hose.
  8. Handheld Toilet Bidet Sprayer Replacement: 步骤 8 中的图像 1,1
    • Screw the T-connector back on the toilet by turning the knob clockwise.
    • Be careful not to cross the threads.
  9. Handheld Toilet Bidet Sprayer Replacement: 步骤 9 中的图像 1,1
    • Screw the water supply nut onto the bottom of the T-connector by turning the knob clockwise. Make sure it is firmly hand tight.
  10. Handheld Toilet Bidet Sprayer Replacement: 步骤 10 中的图像 1,1
    • Screw the water supply hose back on the T-connector by turning the knob clockwise. Be sure not to over tighten the nut.
  11. Handheld Toilet Bidet Sprayer Replacement: 步骤 11 中的图像 1,1
    • Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
终点
另外一个人完成了本指南。
2条评论
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Pete Chisteckoff - 回复
Same concern.
Nuke Engineer -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 111
总计 9,932
