跳转到主内容
Handheld Shower Head Replacement
你所需要的
  1. Handheld Shower Head Replacement, Shower Head: 步骤 1 中的图像 1,1
    • Obtain a replacement showerhead.
    • Modern shower heads and arms are usually compatible with any shower located in the US and Canada. Restrictions may include antique (older than 1994) and other uncommon showers.
  2. Handheld Shower Head Replacement: 步骤 2 中的图像 1,1
    • Unscrew the nut attached to the shower head connected to the wall using a wrench.
  3. Handheld Shower Head Replacement: 步骤 3 中的图像 1,3 Handheld Shower Head Replacement: 步骤 3 中的图像 2,3 Handheld Shower Head Replacement: 步骤 3 中的图像 3,3
    • Unpack the new showerhead. Take note of the type of attachment and what tool you might need to tighten it.
    • Be sure to check with the included manual whether or not you will need thread seal tape, as some showers do not require it.
    • If you need to use Thread Seal Tape, make sure to wrap it with the direction of the threading, so it stays smooth and aligned as you thread the ends together.
  4. Handheld Shower Head Replacement: 步骤 4 中的图像 1,2 Handheld Shower Head Replacement: 步骤 4 中的图像 2,2
    • Attach the nut that threads to the arm of the pipe in the wall loosely; hand-tightening everything for now is fine.
  5. Handheld Shower Head Replacement: 步骤 5 中的图像 1,2 Handheld Shower Head Replacement: 步骤 5 中的图像 2,2
    • Attach the ball jointed segment to the attaching nut, with the nut’s threaded end towards the shower head, facing away from where the ball component was screwed onto the pipe.
    • Ensure that the rubber or plastic washer is in place to prevent leaks in the future.
  6. Handheld Shower Head Replacement: 步骤 6 中的图像 1,2 Handheld Shower Head Replacement: 步骤 6 中的图像 2,2
    • Attach the piece that holds the shower head and attaches to the pipe to the threaded nut over the ball joint.
  7. Handheld Shower Head Replacement: 步骤 7 中的图像 1,1
    • Attach the water hose to the ball joint component, and then to the base of the showerhead.
    • You can place the showerhead in its holding slot for convenience as you attach the line.
  8. Handheld Shower Head Replacement: 步骤 8 中的图像 1,1
    • Finish tightening all components properly with your wrench (do not over-tighten).
    • Tighten down the nut encasing the ball-jointed segment until it will not move or slip on its own, but is loose enough to be gently adjusted with minimal force. This component will most likely not require the wrench, as it is built to be adjusted.
  9. Handheld Shower Head Replacement: 步骤 9 中的图像 1,1
    • Run the water through the showerhead to test for leaks, and tighten or loosen components as necessary.
    • Ensure the ball joint pivots easily in the socket. If it does not, loosen the nut around the ball until it can move (without adjusting the other components).
终点
Aaliyah Kahoohanohano-Davis
于02/20/24注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 52
总计 696
