跳转到主内容
Hamilton-T1 Air Intake and Fan Filter Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Hamilton-T1 Air Intake and Fan Filter Replacement, Air Intakes and HEPA Filter: 步骤 1 中的图像 1,1
    • The fan filter is located on the side of the ventilator and can be removed and replaced by hand.
  2. Hamilton-T1 Air Intake and Fan Filter Replacement: 步骤 2 中的图像 1,1
    • The air intake filter is located on the rear of the device, and can also be removed by hand.
  3. Hamilton-T1 Air Intake and Fan Filter Replacement: 步骤 3 中的图像 1,1
    • To access the HEPA filter, first remove the screw holding the filter cover in place and gently remove the cover.
  4. Hamilton-T1 Air Intake and Fan Filter Replacement: 步骤 4 中的图像 1,1
    • The HEPA filter can now be removed by hand.
    • Install a new HEPA filter and reattach the back panel.
    • Be sure to test the device and ensure airflow through all filters before use.
结论
Trevor Foley
于04/10/20注册
114 声望
撰写一个指南
团队
Cal Poly, Team S11-G24, Paton Spring 2020 Cal Poly, Team S11-G24, Paton Spring 2020 的会员
CPSU-PATON-S20S11G24
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 662
