跳转到主内容
Hamilton Medical Ventilator Replacing the LCD
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Hamilton Medical Ventilator Replacing the LCD, LCD: 步骤 1 中的图像 1,1
    • First open the main enclosure by removing the four hexagonal-drive (Allen) screws at the rear of the enclosure.
  2. Hamilton Medical Ventilator Replacing the LCD: 步骤 2 中的图像 1,1
    • Unscrew the control board mounting plate.
  3. Hamilton Medical Ventilator Replacing the LCD: 步骤 3 中的图像 1,1
    • “Hinge” back the mounting plate, complete with control board. This exposes the LCD.
  4. Hamilton Medical Ventilator Replacing the LCD: 步骤 4 中的图像 1,1
    • Unplug the cable from the GMP adaptor board from the LCD.
  5. Hamilton Medical Ventilator Replacing the LCD: 步骤 5 中的图像 1,1
    • Unplug from the dc/ac board, the cable to the interface board.
  6. Hamilton Medical Ventilator Replacing the LCD: 步骤 6 中的图像 1,1
    • Unscrew the four hexagonal-drive (Allen) screws securing the two brackets on which the LCD is mounted.
  7. Hamilton Medical Ventilator Replacing the LCD: 步骤 7 中的图像 1,1
    • Lift out the complete assembly.
  8. Hamilton Medical Ventilator Replacing the LCD: 步骤 8 中的图像 1,1
    • Unplug both of the lights from the dc/ac board.
  9. Hamilton Medical Ventilator Replacing the LCD: 步骤 9 中的图像 1,1
    • Remove the LCD from the two brackets, by removing the black hexagonal-drive (Allen) screws on the LCD. NOTE: Do not remove the silver hexagonal-drive (Allen) screws on the SIDE of the LCD.
  10. Hamilton Medical Ventilator Replacing the LCD: 步骤 10 中的图像 1,1
    • When fitting a new display, there must be an offset of approximately 2 mm between the plastic sealing strips on the LCD, and the brackets.
  11. Hamilton Medical Ventilator Replacing the LCD: 步骤 11 中的图像 1,1
    • If necessary, adjust this gap using the silver screws on the side of the LCD.
    • The surface of the LCD must be clean. Wipe it free of finger marks and dust with an antistatic paper towel.
  12. Hamilton Medical Ventilator Replacing the LCD: 步骤 13 中的图像 1,1
    • The cable from the GMP to the LCD must be in the cable grip on the control board mounting plate.
    • When screwing the LCD assembly into GALILEO, you must align it with the glass screen in GALILEO. Check this by looking at the front of GALILEO.
    • Turn on GALILEO, and make sure that the LCD lights up, and is properly aligned.
结论
Sofya Shatalova
于04/07/20注册
229 声望
撰写一个指南
团队
Cal Poly, Team S7-G26, Paton Spring 2020 Cal Poly, Team S7-G26, Paton Spring 2020 的会员
CPSU-PATON-S20S7G26
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 251
