跳转到主内容
Hamilton G5 Ventilation Unit Motherboard Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Hamilton G5 Ventilation Unit Motherboard Replacement, Rail: 步骤 1 中的图像 1,1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Ventilation Unit Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the Rail (B).
  3. Hamilton G5 Ventilation Unit Motherboard Replacement: 步骤 3 中的图像 1,1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Ventilation Unit Motherboard Replacement, Main Cover: 步骤 5 中的图像 1,1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Ventilation Unit Motherboard Replacement, Ventilation Unit Motherboard: 步骤 7 中的图像 1,1
    • First, we need to remove the ESM module. It is connected to 2 connector sockets. Disconnect and remove.
    • Take out the Ventilation Real-time Controller (VRC) SW chip
  6. Hamilton G5 Ventilation Unit Motherboard Replacement: 步骤 9 中的图像 1,1
    • Install the ESM Module, by connecting the connectors (A), and the VRC SW chip on the new board.
  7. Hamilton G5 Ventilation Unit Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect all cables and connections from the board to the unit.
  8. Hamilton G5 Ventilation Unit Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the three Hex screws (B).
  9. Hamilton G5 Ventilation Unit Motherboard Replacement: 步骤 12 中的图像 1,1
    • Move the motherboard out then up away from the ventilation unit (C).
结论
Dane Dormedy
于04/08/20注册
349 声望
创作了3篇指南
团队
Cal Poly, Team S7-G25, Paton Spring 2020 Cal Poly, Team S7-G25, Paton Spring 2020 的会员
CPSU-PATON-S20S7G25
6 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 7
总计 277
