跳转到主内容
Hamilton Beach 70740 Power Cord Replacement
你所需要的
  1. Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: 步骤 1 中的图像 1,2 Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: 步骤 1 中的图像 2,2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Power Cord Replacement, Base: 步骤 2 中的图像 1,2 Hamilton Beach 70740 Power Cord Replacement, Base: 步骤 2 中的图像 2,2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  3. Hamilton Beach 70740 Power Cord Replacement: 步骤 3 中的图像 1,3 Hamilton Beach 70740 Power Cord Replacement: 步骤 3 中的图像 2,3 Hamilton Beach 70740 Power Cord Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
  4. Hamilton Beach 70740 Power Cord Replacement, Power Cord: 步骤 4 中的图像 1,3 Hamilton Beach 70740 Power Cord Replacement, Power Cord: 步骤 4 中的图像 2,3 Hamilton Beach 70740 Power Cord Replacement, Power Cord: 步骤 4 中的图像 3,3
    • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
    • From the open base pull the motor straight out.
  5. Hamilton Beach 70740 Power Cord Replacement: 步骤 5 中的图像 1,1
    • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor and then rewire the new power cord to the motor.
  6. Hamilton Beach 70740 Power Cord Replacement: 步骤 6 中的图像 1,2 Hamilton Beach 70740 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Remove the two 12 mm screws using the #2 Phillips head screwdriver.
    • Remove plastic piece.
  7. Hamilton Beach 70740 Power Cord Replacement: 步骤 7 中的图像 1,2 Hamilton Beach 70740 Power Cord Replacement: 步骤 7 中的图像 2,2
    • Remove the three 12 mm screws using the #2 Phillips head screwdriver.
    • Remove the plastic piece by pulling straight up.
  8. Hamilton Beach 70740 Power Cord Replacement: 步骤 8 中的图像 1,2 Hamilton Beach 70740 Power Cord Replacement: 步骤 8 中的图像 2,2
    • Remove the power cord from the ground by removing the solder with the soldering tool.
    • Solder the new ground from the new power cord.
结论
另外一个人完成了本指南。
Travis Williams
于02/02/17注册
552 声望
创作了5篇指南
团队
USF Tampa, Team 17-4, Blackwell Spring 2017 USF Tampa, Team 17-4, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G4
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 830
