跳转到主内容
Hamilton Beach 70740 Internal switch Replacement
你所需要的
  1. Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: 步骤 1 中的图像 1,2 Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: 步骤 1 中的图像 2,2
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Internal switch Replacement, Power Knob: 步骤 2 中的图像 1,3 Hamilton Beach 70740 Internal switch Replacement, Power Knob: 步骤 2 中的图像 2,3 Hamilton Beach 70740 Internal switch Replacement, Power Knob: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
  3. Hamilton Beach 70740 Internal switch Replacement, Base: 步骤 3 中的图像 1,2 Hamilton Beach 70740 Internal switch Replacement, Base: 步骤 3 中的图像 2,2
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  4. Hamilton Beach 70740 Internal switch Replacement: 步骤 4 中的图像 1,3 Hamilton Beach 70740 Internal switch Replacement: 步骤 4 中的图像 2,3 Hamilton Beach 70740 Internal switch Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
  5. Hamilton Beach 70740 Internal switch Replacement, Internal switch: 步骤 5 中的图像 1,2 Hamilton Beach 70740 Internal switch Replacement, Internal switch: 步骤 5 中的图像 2,2
    • Remove the two 11 mm screws using the #2 Phillips head screwdriver.
  6. Hamilton Beach 70740 Internal switch Replacement: 步骤 6 中的图像 1,2 Hamilton Beach 70740 Internal switch Replacement: 步骤 6 中的图像 2,2
    • Cut all four red wires using the wire stripper crimping tool.
    • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
    • Cut the white wire using the stripper crimping tool.
    • Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
结论
Travis Williams
于02/02/17注册
552 声望
创作了5篇指南
团队
USF Tampa, Team 17-4, Blackwell Spring 2017 USF Tampa, Team 17-4, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G4
3 名成员
创作了7篇指南
2条评论
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
Mitchell Arends - 回复
I used a hair dryer and that did the trick, but am wondering if WD 40 would work as well. I went online e with the company and they want $2.00 for tech advice which is dumb to me. At first I thought it was the locking device on top; it is actually the pulse switch and my machine is just over a year old.
joanneferrato - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 922
