跳转到主内容
Hamilton Beach 70730 Drive Shaft Replacement
你所需要的
  1. Hamilton Beach 70730 Drive Shaft Replacement, Bowl: 步骤 1 中的图像 1,1
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 2 中的图像 1,1
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 4 中的图像 1,1
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 5 中的图像 1,1
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Drive Shaft Replacement, Drive Shaft: 步骤 6 中的图像 1,1
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  7. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  8. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 8 中的图像 1,1
    • Using a JIS #1 driver, remove the four 10 mm screws.
  9. Hamilton Beach 70730 Drive Shaft Replacement: 步骤 9 中的图像 1,1
    • Lift the driveshaft off of the base.
结论
Mack Bernard
于03/08/16注册
597 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-4, Isaacson Spring 2016 UMass Dartmouth, Team 2-4, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 957
